blue / black smoke
badly burnign oil can smell it 2..... nasty
need engine swap....
also on the engine swap is it nessasary to get a new head gasket just in case (on the ze)
buring oil badly
buring oil badly
Re: buring oil badly
Do a leak down test and you will see if you have to or not, but a ze with bad head gasket usually has more problems then just the head gasket.
See you in my rear wiew!!
