Oil Drinker
Oil Drinker
Hey guys,
Quick question..I have a KL08 engine and every since i have had it..it seems to drink oil..I mean if I don't check the levels on a regular basis I can actually run out before a scheduled change is required. Now I know there is no leaks and I am not shooting jets of black or blue smoke out my tail pipes..is this something normal or is something wrong?
Friends are just enemies who lack the testicular fortitude to kill you.
I'm a 2min man in a 1min universe
94 GS - KLZE, Spec2 Clutch, Fidanza 9lbs FW, 2 1/4 full magnaflow exhaust. 145WHP / 147WTQ
Re: Oil Drinker
I think its a common thing with the K8 engine. I know mine did that. On occasion mine would puff a bit of blue smoke.
93 GS, KLZE, KL31 ECU, Centerforce Stg 3 Clutch, 2.25" Exhaust w/Flowmaster muffler, OBX Headers, Pheno Spacers, Front & rear X-drilled/slotted Rotors, KVR pads, SS brake & clutch lines, Ractive Filter, H&R Springs, Tokico Blue Struts, 8mm Accel Wires, MSD 6A w/ Blaster 2 Coil, HVAC Indiglo Panel. *Sold*
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
Re: Oil Drinker
is this something that I would have to contend with when I swap to the KL03? Or is it something that is only found on the kl08?
Re: Oil Drinker
All the KL series engines can do it. I have heard it is more common on the 93 and earlier engines. I would avoid using a synthetic oil if the engine mleage is higher. This can make your engine start using oil or make it worse if it all ready is.
91 Eagle Talon Tsi AWD *RIP*
Re: Oil Drinker
if it is common for the K8 then my engine....is very uncommon... It doesn't drink a bit, even though I like to floor the gas pedal pretty much every day . My K8 has some 65 thousand kilometers done so I don't know how will it do after 100 thousand more!
"For those 10 seconds or less, I am free"
Re: Oil Drinker
Well who knows cause when I picked my car up it had 140k on it so maybe once yours reaches 100k it might develope a drinking problem hehehehehe
Re: Oil Drinker
Mine had 171,000, before I swapped it over to the KLZE
- MX3-Freak
Re: Oil Drinker
How would switiching to a better oil (synthectic) make your engine run worse/ burn oil?
Stock 1995 RS - Creek Blue
Car Meanins:
Car Meanins:
Re: Oil Drinker
I've got a '92 with over 100K miles, I'm over 6,000RPM every day, and run synthetic Royal Purple. I don't loose much if at all. If I put 5 quarts in, I know I get AT LEAST 4.7 quarts out.
Re: Oil Drinker
On my ole MX-6 when I switched to synthetic I went from using 1 quart every 3,000 miles to 1 quart every 750. I also had a Honda civic Si that started using oil right after the switch to synthetic. I've heard of many other similar stories on higher mileage older engines. I can't say exactly why it happens. I can say there is a chance it will.
I only use regular old dino oil now. Mobil is what I'm using now but Havoline has been good to me also. I use it for a few reasons. One is it's about 1/2 the cost or less of synthetic. Another is I have never heard of someone losing an engine due to the oil. Maybe after 150,000 miles one engine might be in better shape than another. I never keep a car that long to worry about it. I just change the oil and filter regularly and life is good.
- MX3-Freak
Re: Oil Drinker
Well of course, I didnt see what you wrote. Synthetic oil has very strong cleansing abilities. If you just start dumping in synth after 150k miles of crap regular oil, of course you will start having oil problems. Oil made from crude leaves depostise on the engine as it breaks down, synthetic leaves none (partly because its so damn heat resistant). After 150k miles of deposites on the engine, then you put a cleansing oil in, guess what happens? The deposties are removed! Now, that is a good thing in some cirumstances, however, when you leave those free deposties in for another 7,500 miles (recommended oil change for mx3), they will reak havoc on all your seals. This leads to oil buring. Thus, it was not the synth oil that caused you oil buring problems, it was the regular oil.
How do you avoid this and still switch over to sythetic oil on a high milage engine? Simple, before you switch over, do an engine flush to remove all the deposites before the sythetic oil is used. Then not only will your not consume more oil, but your seals will last longer, buring less oil.
<small>[ April 16, 2004, 12:39 PM: Message edited by: MX3-Freak ]</small>
Car Meanins:
Car Meanins:
