Hello
I dont know where to post this so I will try here.
I noticed today that my 93 mx-3 was slightly damp around the passenger rear amd under the passenger seat. So I lifted the carpet and its very wet under there. Has anyone had this problem or does anyone know whats causing it? Will it be expensive to fix?
Thanks
NEED URGENT HELP!!
- 93-Spec-Edn
NEED URGENT HELP!!
92 mx-3 RS RIP | 95 mx-3 GS sold | 93 mx-3 GS SE sold | 95 mx-3 GS present
- Zoso124
Re: NEED URGENT HELP!!
Maybe the floor is rusted through or your little brother split his slurpie.
Mike Evans
Gone:
Gone:
- mitmaks
your glass seal/rubber might be leaking somewhere or heater core leaking
- 93-Spec-Edn
Is th eheater core under the passenger seat? There is a lot of undercoating under the car and there seems to be no rust.
any other idea b4 I pay a dealder to check it out?
I had the same thing happen. It dried up and hasnt happened since, so I figured someone spilled something.
It could be the heater core IF its more wet in front of the seat than under the seat.
Shaun Newman
- 93-Spec-Edn
Thanks for the replies.
I think I know what the problem is. There are no cracks under the car. However the passenger door does not seal properly. If u put your fingers in from inside between the door and the frame there is a much much wider gap than in the drivers side. Anyone know how to fix this?
Thanks
Thanks
