ZE wont start
ZE wont start
Ok I know this has probably been posted a thousand times but I really need help.
I installed the ZE in the other night and it fired right up, but the exhaust wasnt hooked up so it was to loud so we couldnt keep it going. So the next night we put the stock manifolds on and downpipe, but no muffler and it fired right up, we had it running pretty smooth but when we went to move it out the door it died, and we just cant figure out what happened, but what we noticed was that the first night the fuel pump was humming like crazy, but now we cant even hear it turn on. I did install a new timing belt when I put the engine in and im using the millenia manifold. and I dont have the front 02 sensor hooked up right now because I had to have my headers modified.
any help you guys could give me would be great. we just cant understand how it started so nice but when we tred moving it, it wont start again.
Re: ZE wont start
check for power at the fuel pump, if no power check the relay and the fuel pump fuse, maybe the clutch switch?
if it has power, make sure that the pump is working.
Yes, I AM a bastard
Yes, I AM a bastard
Re: ZE wont start
What I found weird was the first night it started I could hear the fuel pump just a humming and now theres no noice at all and I have my back seat out and everything.
- papa roached
Re: ZE wont start
then i would say the fuel pump aint pumpin
Re: ZE wont start
do what I said to do.
Yes, I AM a bastard
Yes, I AM a bastard
Re: ZE wont start
There is power but there is no huming or any sound comming from the fuel tank.
Re: ZE wont start
pull the rear seat bottom out of the car, then remove the cover on the floor, with someone cranking the car, have some one bang on the top of the fuel tank with a hammer, if the pump starts to work and the car starts then you need a fuel pump.
if it still wont work then remove the fuel sending unit from the gas tank, then check for power right at the fuel pump its self.
If there is power right at the terminal of the fuel pump then it needs a fuel pump.
if there is no power at the fuel pump but there is power at the connector for the sending unit, then you need to either clean the rterminals or replace the sending unit.
Yes, I AM a bastard
Yes, I AM a bastard
Re: ZE wont start
This sounds stupid but somehow I've managed it twice. After changing the engine in my RX-7(which I did a total of 5 times) I had just enough fuel for the car to run for a minute or two then it was dead empty. Since it was right after a motor swap and it did run adding a gallon or so of fuel to fuel tank never crossed my mind. The first time I did this it took me a week to figure it out. It sounds very stupid, but sometimes its the obvious, easy things we tend to overlook
91 Eagle Talon Tsi AWD *RIP*
Re: ZE wont start
Thanks for the info, have anymore suggestions.
Re: ZE wont start
sounds silly but did you check for spark?
Re: ZE wont start
Ok I figured out I got fuel, I got spark and I got compression, The only thing we can figure now theres something out of time, cause it sounds like it wants to go but, just wont fully kick in. I did install a new timing belt when i installed the engine, could it have jumped the timing cause the car did fire up at first but died when we went to move it. any help would be great.
Re: ZE wont start
1) are the fuel feed and return lines hooked up properly or did you revese them by mistake?
2) is the engine flooded with gas.
Yes, I AM a bastard
Yes, I AM a bastard
Re: ZE wont start
Ok played with it agian tonite, come to find out I only have 40psi of compression on the back 3 cylinders, but what I dont understand is that it started up and was running smooth so them back cylinders must have had more compression then that before, could it be anything to do with the cams cause I had them out and had them regrinded.
Re: ZE wont start
Hey curt how could I tell if the lines are reversed.
Re: ZE wont start
could the cam timing be off inside causing it to have no compression?
or could the engine be washing down, causing it to have no compression.
cause I really dont think its rings cause the engine started and was runing fine. for like 5-10 mins.
come on guys anyone have anymore ideas
