Preformance Axles
Preformance Axles
I'm planning a ze swap this summer in my 92 gs and I want to know where I can get axles that will handle about 250+ whp. and about how much I can expect to pay cnd. The reason I'm getting the axles now is because mine are just about gone.
Re: Preformance Axles
i believe you can buy them from driveshaftshop.com
1992 MX-3 GS
KLZE - Fidanza Flywheel - CM IIR Clutch - Millenia IM - UR Pulley - IM Spacers - KL36 ECU
...you do know that Canadian Tire sells axles for our car (1.8L GS) at $87usd each. That comes with a LIFETIME WARRANTY!!
Will stock axles handle the ze's hp?
- Zoso124
Stock axles will handle a ZE's power. How are you planning on hitting 250+whp?
Mike Evans
Gone:
Gone:
I think his point is the lifetime waranty. You break it, you swap it again. You can probably get at least a year out of each one. I believe the people who's axles fail most often are lowered. If your ride height is low, then it may increase the service interval even more.Originally posted by Eggo:
ok maybe I'm over estimating the amount of hp I will be putting to the ground. I want to run a ze with obx headers, cold air, port and polish, and NOS. I plan on lowering my car with either eibach or supension techniques springs with zx2 struts but lets not make this a disscution on that. So with a 1.5-1.8" Drop and a ze with just an intake and exuast can I get away with stock axles?Originally posted by Zoso124:
The Canadian Tire lifetime warranty only works if you pay them to put the axles in - but I wouldn't let any Canadian Tire "mechanics" I know touch my car!
Oh really!! I think i'll just have to pay them a visit then. Cause i asked the guy on the phone "Does this come with a lifetime warrany?" he said "yes"...and im like, "Are you sure?"...and he says "yes".
So stock axles should be fine for Daily driving a car with a 1.75" drop and 200hp right?
