help finding topic on Kers. engine flush
- monstar-mx-3
in the last month some posted a topic to flush the engine to clean out the crap out of the egine and stop the ticking. I did a seach , but i dont know what its under. can sone please post the linkl.
Re: help finding topic on Kers. engine flush
If you search on "kerosene" its the first topic it finds, but when you click it, it returns "you are requesting a topic which does not exist".
Bug on the board.
Bug on the board.
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system![Smile :)](./images/smilies/icon_smile.gif)
- mitmaks
add a quart of transmission oil instead of regular oil on next change it should take care of hla noise
Another option might be trying the stuff at www.auto-rx.com
It's pricey, but is supposed to be less harmeful. It's basically just a metal cleaner from what I can tell. I just added mine. Supposed to run 1000 miles, then run another 1000 miles on non-synthetic to finish the flush. I'll let y'all know if it does anything worthwhile.....because the kerosene flush thing really didn't do anything.
If you really want to try the kerosene thing, look in your auto parts store for something called '5 minute flush' or somethign like that. That's basically a kerosene. Not sure if it's 100% kerosene, but I know it's at least part kerosene.
<small>[ February 15, 2004, 06:09 PM: Message edited by: lakersfan1 ]</small>
The link below will take you to the info on the ProbeTalk site. You will probably have to register to see it.
ProbeTalk
ProbeTalk
1992 MX-3 kl-ze, atx-to-mtx conv.
1993 MX-3 RS atx
1993 MX-3 RS atx
- monstar-mx-3
great thanks. I can see it on the seach menu..but i cant pull it up.
