Unorthodox UD pulley question?
We tried to install one on my Kfze engine the other night and ran into a bit of a snag, the back frame that comes on them keeps it from aligning with the waterpump pulley, has anyone had this problem as well? we thought maybe by removing the plate it would give us enough space for it to fit, we also considereing giveing the block a little shave so that it will work. Now i compared Part #s between the Kl03 and the k8 engine both use the same underdrive pulley so im sorta stuck on this, any commentary would greatly be appreciated.
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- jaydog5678
Re: Unorthodox UD pulley question?
Brian, I noticed Kevin's KL-ZE did'nt have the interferance on the block for his underdrive pulley. I think the castings are a little different in that respect. We could cut some of the casting out like we talked about earlier. What do ya think?
- babyblueMX3
hey man i replied to this post but don't know where it went..anyways on my klze too i had to cut the oil pump housing for about a inch or so...it was all detailed in teh instructions..didn't they came with your pulley?
RIP 400whp ZE-T MX-3
- papa roached
yea, cutting the pump a bit is in teh instructions
ne body know how much of a gain in performance you get with that?
94 mx3 gs (sold)
92 Mitsubishi Eclipse GSX(14.3 @ 99.08- almost completely stock)
- Zoso124
Yes, these guys are right, all the blocks are the same you have to cut the lip off the oil pump. No other way to do it.
Mike Evans
Gone:
Gone:
k thanks guys!
The plastic timing belt cover needs trimming a bit as well.
