Kl-de build up! how much hp is possible?
- jaydog5678
Re: Kl-de build up! how much hp is possible?
The Kf was never in an American car. It was only a Japanese replacement engine.
It's not the best idea to shave the heads to raise the compression. Taking away to much from the head's will retard cam timing slightly. If thery're warped or just a little out of level go ahead and clean it up with a light cut. Your best option is to run a higher compression piston (ZE piston or even higher).
ok. thanks for all the help. as of right now im going to get the ze pistons from corksport, maybe ze cams from this guy, maybe the underdrive pulleys from corksport,and the thermo spacers from outlaw engineering, and maybe the bigger throttle body. ne thing else i should get?
I have already read the thread on probetalk. im askin u guys.
<small>[ November 01, 2003, 02:00 PM: Message edited by: BucktownMx3 ]</small>
94 mx3 gs (sold)
92 Mitsubishi Eclipse GSX(14.3 @ 99.08- almost completely stock)
Some headers.
Mods:
- ZE, Mike seli 214 intake cams, Ported n polished heads, Interprep valve springs, DE retainers, rebuilt bottom end, toga main and rod bearings, toga hv oil pump, CZT 67mm tb, mbx udp, ported intake mani, SS headers, 2.5inch full exhaust, racingbeat muffler, highflow cat, megasquirt v2.
new toy, 86 TII rx7, JDM S5 motor/turbo, + alot of other goodies
- papa roached
well, with ZE pistons and ZE cams, you have a KL-ZE :p
Ze heads have larger exhaust valves aswell. Flow alot better then DE heads too.
Mods:
- Zoso124
Oh really? Proof?
Mike Evans
Gone:
Gone:
I dont have any proof. But i remember reading it somewhere... The only reason i beleived it was that some ZE's have tendancies to break retainers more then DE's so i throught it was because of the larger valves. If i'm wrong prove it.
Mods:
Still need a ZE intake manifold.Originally posted by papa roached:
BTW- I have a set of KLZE cams I'm selling. $150+shipping
91 Eagle Talon Tsi AWD *RIP*
Valves are same size, discussed here and on probetalk many times, don't have to prove a thing to you.Originally posted by T-Rose:
ok will the kl-de ecu do ne thing performance wise for the K8? i mean if i have to ill get the ze ecu for my kl-de built up motor im just wondering if the 2.5 ecu will do ne thing for the 1.8?
94 mx3 gs (sold)
it's because ZE's have fiercer cams not because of larger valves. If you were to say put K8 cams in a ZE block the valve retainers would last forever...but performance would suck.Originally posted by T-Rose:
yes it will suck. I did it once out of curiosity...idle was incredible. Dead smooth. but accelleration was pathetic. Totally gutless.Originally posted by BucktownMx3:
the fuel map on the K8 is better than the KL. (that's why a K8 ecu will work great on a ZE if a ZE ecu is not available)
about the ecu's, i would suggest you check bulk buy section on probetalk. This guy can program a chip for you, put whatever you want for VRIS points, and air/fuel I think. This will be very helpful for your build up engine. The only problem is that you will need someone to solder that instead of your existing.
Check out my ride and leave some feedback please!
http://www.cardomain.com/id/mradio007
whats is the quickest e.t. form a kl-de? and what are the mods done to it?
94 mx3 gs (sold)
oh yeah and whats the best clutch to use?
94 mx3 gs (sold)
