ok here is what I got
KL-03 (need vaf and ecu)
KFZE (need ECU only) do I also need a new clutch?
KLZE (ECU and clutch and Millenia MANFIOLD) is their anything im missing guys
questions and info.
Re: questions and info.
You have all three of these engines?Originally posted by MMike:
lol no im trying to choose one is that all the parts i need? If not what else also wha r the specs i know klze is 195hp 160torque thanks.
I would suggest a resurfaced flywheel and a new clutch with any engine you put in. Its easier while the engine/tranny is out.
92 MX-3 GS 2.5 KLZE
14.385 @ 98.21
14.385 @ 98.21
