Running a ZE on 87 octane?
What will happen if I stop using 93 octane gas?
Previous posts say either nothing as the ecu with automatically retard the timing to prevent detonation or the engine will knock due to pre-detonation? As these 2 views are exactly opposite it would be good to know the right answer!
- papa roached
Re: Running a ZE on 87 octane?
i wouldnt, its a high performance motor meant to use premium, i wouldnt stop using it
Even the regular K8 doesnt like 87, i wouldnt risk it if i were you. Dont be cheap!
Mods:
- ZE, Mike seli 214 intake cams, Ported n polished heads, Interprep valve springs, DE retainers, rebuilt bottom end, toga main and rod bearings, toga hv oil pump, CZT 67mm tb, mbx udp, ported intake mani, SS headers, 2.5inch full exhaust, racingbeat muffler, highflow cat, megasquirt v2.
new toy, 86 TII rx7, JDM S5 motor/turbo, + alot of other goodies
got that right....putting 87 octane in a high rev engine is like playing a record on slow setting.Originally posted by T-Rose:
It was the post aboout ZE fuel economy that got me thinking - if premium is 10% more expensive than regular would I get 10% more fuel economy or 10% more pleasure? Probably not both - as I only use my car to commute back and to work there's only so much horsepower I can use getting up to 80km/hr on the fastest stretch into work!
- papa roached
dont be cheap, that motor is not meant to have 87 in it or even near it
the motor was designed for premium fuel. I think the recommended japanese rating was 102 octane, which is close to what our 94 octane is here. I use 92-93 in mine, since the octane ratings at gas stations vary between my sea-level hometown, and 1500ft elevation college-town.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
okay so I'm cheap but will 87 wreck the engine?!
You might get some ping or knock. Dont risk it man.
Mods:
If you are not prepared to run 94 in your Ze, then stick with the stock engine. My Ze does not even like a 92 downgrade, pretty picky eh?
- papa roached
you cant be cheap with a motor, if you do you can end up with a nice hole in the top of your piston or a bent rod
Sorry to be a pain but what does the knock sensor do then? I thought it listened for pre detonation and then retarded the ignition before any damage could occur - I would expect to lose some hp but not wreck the engine if this were the case.
- papa roached
its for the occasional knock or ping, they do happen, its to keep the motor safe while still running the octane rating meant for the car, not for running a octane rating WAY below what the motor calls for
I've always used 87 in my V6, and have never experienced knocking. The manual states 87 is fine.
<small>[ October 15, 2003, 03:02 PM: Message edited by: UoMDeacon ]</small>
So your manual applies for the KLZE engine too? Riiight...
use 87 if you want...we don't care if you blow up your engine
DONATE TO MX-3.COM
DONATE TO MX-3.COM
