ECUs
- papa roached
ECUs
where can i source 2.5L ECUs to run a KL-ZE? like what cars, probe gt, m-6, etc and will a automatic KL-ZE ecu run a 5-speed KL-ZE MX-3?
<small>[ September 28, 2003, 08:13 PM: Message edited by: papa roached ]</small>
Re: ECUs
Lazzyie will get u a ze ecu. All KLZE's are autos but the ecu you get will work. The only thing is the VRIS points are off. The ZE points are a little higher than the MS8. If you get a VRTuner you will be fine.
65 shot > V8
Re: ECUs
wouldnt the mx6 that had the ze have had a 5speed?
Tom Alexander
Re: ECUs
I get ecus. The Jspec Millenia klzes are all autos and can be run with a kl-62 ecu/kl-43 Maf(i think) but it requires some rewiring. Yes there were 5 speed jspec mx6s those are the straight necked zes. The ecu for these cars are the ones that I offer. Since you already have a V6 mx-3 you don't need to change air sensors to run the jspec ecu. Oh and no if you want to run the kl-62 ecu you have to have an automatic.
*Sidenote=Radiohead is the best band ever
Hope that helps....
Hope that helps....
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi![Smile :)](./images/smilies/icon_smile.gif)
96 Integra LS DD
91 Crx Si drag car
Re: ECUs
Lazzyie, dude why am i on your ignore list? I'm trying to get a klze ecu. Write me at mx3man83@yahoo.com please. Thanks.
My Cardomain site
My Cardomain site
Re: ECUs
Lazzyie, I'm swapping a KL03 from a ford probe '94 into my car (93 mx-3 gs), which ECU should I get. I've asked this question before but the response wasn't all that clear. And since you sell them, I'm sure you could give me a direct answer. There was a change in ECU's with the KL03, or KLDE IN THE PROBES. OBI vs OBII i think...there was a change. What are your thoughts???
-jz
-jz
- papa roached
Re: ECUs
i have heard a KL-ZE ECU will give you some small gains
Re: ECUs
You need a 93-95 probe or MX-6 V-6 ECU and air meter
91 Eagle Talon Tsi AWD *RIP*
Re: ECUs
OOPS- didnt even look who posted.
As far as getting a KLZE ECU this place- www.tigetdirect.com is selling them for $150
Re: ECUs
umm, where on that site, by chance are they found?
I found some nice computer deals...but no klze ecus![Smile :)](./images/smilies/icon_smile.gif)
Tom Alexander
Re: ECUs
Zebaj best source for aspec ecus/vafs is:
www.car-part.com Not to confuse you more but all you need is the air sensor. I can't get the dyno plots anymore but an aspec k8 ecu/kl vaf runs the KLDE better than the kl ecu/kl vaf does. Food for thought.
$150US??????? That's sooo much cheaper than I get them for must be nice to be able to buy in bulk.
<small>[ September 30, 2003, 06:22 PM: Message edited by: lazzyie ]</small>
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
Re: ECUs
did everyone get that okay???Originally posted by lazzyie:
good...I don't want to have to argue this very point anymore.
- papa roached
Re: ECUs
now im getting lost, i want to car to run like it should, not having to get one of them VIRS controllers, i just need the VAF from a Probe or MX-6 and my ECU and it wont run really rich and will run better than with the VAF and KL31 ECU?
