Outlaw Thermal Insulators
I have seen the banner at the top of the page for the Outlaw Engineering Thermal Insulators... are they for the KLZE or the K8? And... what exactly do they do?
- babyblueMX3
Re: Outlaw Thermal Insulators
they make it for both ZE and K8....they keep the intake manifold cooler by insulting it from the heads with phenolic...
RIP 400whp ZE-T MX-3
so it's really rude then!
they're only *insulting* if they're having a bad day. :p
I have a set on my ZE, they are high quality. I've read some guys on Probetalk claiming they don't do anything for power, and I wouldn't know since I have nothing to compare it to, but IMO the manifold does seem cooler after a hard run at the track, but it can still get ridiculously hot
DONATE TO MX-3.COM
DONATE TO MX-3.COM
I have run them on my MX-6. It does seem to make the intake manifold cooler. Did they make any power?? I'm not really sure. I'm getting them for my KLZE swap in my MX-3 so I can't be to upset with the performance of them.
91 Eagle Talon Tsi AWD *RIP*
even if it does give more power the number would be so small you wouldnt notice it, but its still a good idea to do cause less heat is better than more heat
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
how much higher do they make the IM? What about the gaskets?
They move it up ~1/4". I didn't use any gaskets when I put mine in. I just put gasket dressing on both sides of them. Gasket dressing isn't the silicone stuff its a thin brown tacky substance.
First of all, read my sig, Im a bastard, and I have no self control, and you made it SSooo easy.Originally posted by Johns93GS:
Come on man you spent the time tor type out this rediculas question ? when all you had to do was click on the banner to find out the answers? What the hell is that?
PLUS if you did click on it, the web site gets paid for it, they are paying to advetise on here, so basicly you wasted your time typing, my time to carve you up, other peoples time to read all the posts, and you cost Jeff the owner of the site money, way to go.
Yes, I AM a bastard
Yes, I AM a bastard
Why not someone who is going to buy em do the test for everybody? I mean, same engine condition, same water temp, difference between before and after the install. I suppose nobody is going to unbolt his manifold to test that ( or there is?)
European Mx3 GsRT
And you're kinda cute tooOriginally posted by curtklze:
First of all, read my sig, Im a bastard, and I have no self control, and you made it SSooo easy...Originally posted by Johns93GS:
it has been done.Originally posted by BATTOSAI:
Luc St.Piers GSR page has a nice write up about it. My IM is way cooler after installing the spacers....however after the car has been shut down the heat gradually crosses over. for the price..it is a worthwhile mod.
The action of the IM in heating the inlet air is the reverse of an intercooler in a turbo'd engine. If you compare the IM to the intercooler, in terms of the amount of metal in contact with the moving air, its fairly easy to see that the IM is not going to be very "efficient" at heat transfer. So, despite the fact that the metal is noticeably cooler, I would expect the benefit of the insulating spacers in preventing the air being heated to be pretty small. I think you'd be lucky to see a measurable effect under normal road conditions.
A comparative set of dyno runs would be interesting.
<small>[ September 30, 2003, 04:22 PM: Message edited by: IanL ]</small>
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system
