Cruise Control problem
Hi guys, I have a problem:<p>My car is equipped with Cruise Control System, but it is not working at the moment, I checked on the Online Shop Manual but that section isn't online yet... I figured out I need a sort of vacuum hose running somewhere... but don't know exactly where.<p>Can you help me?<p>Guido
-italian lonely MX'er-
Re: Cruise Control problem
Check your vacuum lines. One of mine had come loose and caused me problems with the cruise control.
yeah, i second that. Check the vaccuum line from the cc to the manifold on the passenger side of your engine bay. This happened to me after the swap was done, they forgot to hook it up, and i had no cc!
Tom Alexander
