klze help
klze help
im getting a klze and i want to use its intake manifold what would i have to do to do that. also could i use th exuast manifold
Re: klze help
If you get the curved IM, you can use it no problems, if you get the straight neck, you have to save off of the Tb in order to get it fit .
The exuast manifold will fit.<p>[ May 17, 2003: Message edited by: Gabi ]</p>
See you in my rear wiew!!
Re: klze help
what would i use for an air intake box or cold air intake
