Hi all<p>I'm running the kl-ze with my 1.8 ecu.
I went to the track today and got high 14.
Will there be any improvement by running the kl31 ecu?
I should get low 14 and it's not because the way I drive it.
My friend tried it to and he's a real good driver and he got the same time as me.<p>
The idle sucks not to mention the milleage.
When I hit the brake the idle goes up and down.
I know the ECU will solve this but will it get more power?<p>[ April 06, 2003: Message edited by: leiden ]</p>
improvement with kl31 ecu or not?
Re: improvement with kl31 ecu or not?
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi
96 Integra LS DD
91 Crx Si drag car
as for the idle jumping when u hit the break...i am almost positive that there is an air leak somewhere due to the fact that my idle still jumps when i hit the brake....but just to make sure ill check when i get back from school to see if it still jumps around.....<p>aj
resurected KL-ZE,ZE ECU, 9lb Fidanza Flywheel, CMIII, home depot CAI, Hiflow Cat, 2 1/2" piping, exhaust, 2 MASS 2012's, Cadence A7, Blaupunkt Casablanca, and a no damn CEL light!!!
14.4 is not bad at all !<p>I think the car drives now I'll never drive 14.4<p>I hope the Ecu will do something about that.
how about the of gas with the k8 ecu?
And how about running the engine when it's cold?
Mine sounds like a harley when it's a cold start and a lot of smoke because it is gettin to much fuel
Antwawn would run a 14.0 with the ze ecu plus more torque search this topic , it's been done
13.023 @ 105 mph
Yes, I saw track times of 14 or even lower but I want to know what they run with the k8 ecu and after the replacement with the kl31
