Valve cover removal
Valve cover removal
i need to change my BACK valve cover gasket . I was wondering if all i had to do was take off the intake manifold and then valve cover of will be runnig into other things that are not visible. and is there anything special i have top do when taking either of the two off? any help is appreciated guy /gals thanx
Re: Valve cover removal
yea, all you have to do is take off the intake manifold and all of the antifreeze hozes that are attached to it, also mark your vacuum lines, so you know what order to put it back together. And get a torque wrench if you can, to tighted the IM bolts/nuts.
The other thing, I don't know if you already knew that: cover the intake inlets in both head so you don't get anything in there, and follow the online shop manual.
Good luck
Good luck
Check out my ride and leave some feedback please!
http://www.cardomain.com/id/mradio007
Also it would be wise to clean the inside of your intake manifold!
2.5 KL-ZE, BBS rims, I the front i have to falkin Azenis, Intrax Springs, CM Stage 1 clutch, and Fidanza flywheel, Pacesetter short shifter, Tociko Blue Struts, Sparco Steering Wheel, Yellow Top Battery
Alpine Type R Subs 10's, Alpine 2 Channel Amp, Alpine 4 channel
Amp, Alpine Alarm,Alpine Headunit
14.8 @ 94.2(with vaccume lick)
- Aston Wards
...and buy some plasters for your bleeding knuckles! ![Very Happy :D](./images/smilies/icon_biggrin.gif)
91 Eunos Presso KF-ZE
89 Nissan 300ZX TT 2+2
90 Nissan 300ZX TT 2+0
![Image](http://i2.photobucket.com/albums/y20/ViciousZ32/carbanner.jpg)
i have mine off now what should I use to clean my Intake manifold ?
thanks
Kris
thanks
Kris
93 Kandy Tangerine Mx3 GS-DE
02 Subaru Impreza OBS
& Lots of Toys to haul![Very Happy :D](./images/smilies/icon_biggrin.gif)
Break Part Cleaner, dont lose the straw.
or Carb/Choke cleaner ![Very Happy :D](./images/smilies/icon_biggrin.gif)
I forgot,
you can use the cleaner and the metal brush on the intake runners. After you are done scrubbing wash it away with the cleaner.
- PATDIESEL
Make SURE that you use a good torque wrench to tighten up the velve cover bolts. They are speced to 10 lbs. I believe. I know becuase I broke one off at about 12 Lbs. Not fun, if one breaks you have to remove the whole valve cover and get a new bolt then retorque all the bolts again.
