does it idle rough?<p>what is the outside temp? cold in sweden
?<p>buy platinum spark plugs
<p>possible weak spark problem
it does like to stall at lights so it could be air leak or pcv valve malfunction.<p>check pcv valve from vavle cover to intake, that may also fool the cpu into a vaf code
