kl injectors+safc= stoicho ratio?
I heard that larger injectors need ECU programing to work properly. If we have an Apex'i s/afc and Kl injectors, can we control them to spray correctly at idle?<BR>How much large are they comparing to the K8 ones?<BR>Does the ford Probe has the same fuel pump than the Mx-3?<BR>What´s the stock fuel pressure on a K8?
European Mx3 GsRT
Re: kl injectors+safc= stoicho ratio?
Have you tried using the KL01 or KLZE injectors with your K8 using your stock ECU. I dont know how much more they put out but from what I have done and read about it seems to work and feels as if you gain a little. As for the ford probe having the same fuel pump as the Mx3. I think probes pressure range is a little larger. What you could do is to use a Walbro fuel pump 190 or the 255. Try experimenting with different combinations mix and match.
