high idle
high idle
I just finished installing a set of phenolic spacers, a little port matching, and throttle body bypass. I have tried to adjust my idle down from the current 1,200 Rpm with the adjusting screw under the TB and with the adjustment on the throttle cable. It still idles @ 1200 rpm and in drive it's at 1000 rpm. Should i hook up the coolant lines back to the TB?
SOLD - 93 GS Custom intake, exhaust, phenolic spacers, port matching, front upper strut bar, 17" wheels, dragon body graphics, black/white interior, sound system, tints, altezza tails & 3rd brake altezza, g-force front
'94 Caprice - rolling fast and low on 20's along with some custom goodies
'86 Regal - Hydraulics, custom wheels, custom paint, shaved, phantom top, leather, power, and lots of chrome
'92 - New import project in the works, should be out in '09
Re: high idle
i dont think it will...i think its idling high because of all that extra velocity and air coming in. with the phenolic spacers and port matching. well this is to my knowledge...i could be wrong. maybe your idle screw is busted.
- team slideways
- team slideways
Re: high idle
dont forget to put the car in diagonostics mode while you adjust everything, and reset your computer
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi
96 Integra LS DD
91 Crx Si drag car
Re: high idle
Yes, hooking the coolant lines back up to the throttle body should return your idle to normal. It is possible to improve your idle with the tb bypass but making it perfect seems to be very illusive. I think even Dave had to learn to live with a little fluctuation in his idle with the tb bypass.<BR> Its a sacrifice some are willing to make.<BR>Andy P. 93 GS
Re: high idle
Today it idled a lot better. I have the idle adjustment screw out all the way. How do i go about putting it in diagnostic mode when i'm adjusting idle?
Re: high idle
to put your car in diagnostic mode you have to get a jumper wire or something to hook up to pin 10 and the grnd pin on the diagnostic box between the firewall and your battery. its fairly simply. hope this helps. oh yeah there is a diagram on the inside of the cover letting you know which pin is 10 and wich is ground.
Live your life a quarter mile at a time!! Payback is a mother!!
Re: high idle
yea i'v e done that before to retrieve trouble codes. So, i just have to put the jumper wire in while im adjusting the idle?
Re: high idle
have you tryed adjusting the throtle position sensor, I did all the saem stuff and it helped on my car. It idles around 1200 on a cold start, but once it gets warm it's around 700
Re: high idle
How did you adjust the Tps? I think it has adapted a little more since driving it. It idles at 1200 - 1400 rpm in the morning 50-60 degrees, but drops to about 900 when warmed up and sometimes down to 700 after i get on it an come to a stop light rather quickly.
