2.5 fuel system on a 1.8
Ok, so the heads can't be swaped but what about the fuel rails, fuel pressure regulator, or the fuel pump? Can they be swaped for 2.5 parts? Are they the same parts as whats on a 1.8? Would there be any gain to having more fuel at the valves if you could get more air to the valves by using a 2.5 throte body?<P>Also can you swap a crank for any gain?<BR>Possibly make a stroker?<BR>as you can likely tell i'm looking for cheap performance gains, since kl-o3 parts are easily obtainable for cheap here. People keep saying you can't swap any parts but I don't believe it! I'll find some stuff danmit!
Re: 2.5 fuel system on a 1.8
why not just save up and by a kl-03 for like $500-$600 and swap the whole stupid engine rather than trying to swap parts?
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi
96 Integra LS DD
91 Crx Si drag car
Yes, if you could get more air in the engine, more fuel would be a good idea. The question is, how are you going to get ~40% more air in the engine?
David Coleman
- mrspanky79
Do not use the 2.5l fuel rail on the 1.8l!!<BR>Im runnign the 2.5l fuel rail right know on my 1.8l because i will need it soon but i will tell you you will get a huge loss in power and the computer dont like it. Way to much fuel, at 2000rpm its running rich.
War does not determine who is right, war determine who is left!
94 mx3 GSX Stroked Turbo'd and Intercooled
99 vitara 4x4
99 vitara 4x4
would swaping to the 2.5 throtle body and set up a ram air intake be enough to get a performance gain out of the 2.5 fuel system?<P>also what about a crank, can they be swaped?
- mrspanky79
on a 1.8l no
99 vitara 4x4
99 vitara 4x4
