intake tube cracking
- Buff1110
ok my stock intake tube is cracking through the ripple like areas. instead of replacing the tube with another, what other options do i have or whats a good way to make my own since this piece cannot be reused?<BR>Dan
Dan
92 Mx-3 Gs, KLZE Powered!! - SOLD!!!!
02 Tacoma TRD - Daily
93 Honda del Sol - New Project
Re: intake tube cracking
Buy some silicone hose from any one of a dozen or more sellers on the net.
I used a silicone coupling to mount the VAF to the TB, i put a PVC 90 degree on the VAF that went straight down, then put a cone style filter an the end of that.<BR>This system replaces your intake tube and gives you a cold air intake for really cheap
Do you have pictures and stuff of you coldair install... Maybe some instructions? I not sure what all that stuff is that you said..lol ![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
I can't take credit for the idea. Go to the V6 FAQ board on this site, there is a FAQ titled "homemade intake", it has pictures and very detailed instrutions. thanks for posting that Dave
ok went there and I understand alot more now, however I am still confused as they say nothing about what to do with those vacuume lines?
- Buff1110
u put brass fittings into the pipe and connect the hoses to them.<BR>Thanks guys for the quick response.<BR>Dan
Dan
Do you have any pics? Where do I get these brass fittings?
Hardware store.
