klze finally :)
klze finally :)
sup guys,<P>I finally booked my engine swap...last week of august...<P>I decided to go with A-SPEC, because it seems they have the best reputation and the price is right. I decided also to get my clutch done...in fact im just getting it ripped out, and I asked them to put a stage 3 copper puck clutch in. <P>Anyone else go with A-spec ? <P>I cant wait for my first test drive in it...<BR>later.
Tom Alexander
Re: klze finally :)
Make sure that's a sprung hub clutch or you'll regret it.
Re: klze finally :)
think the clutch is a bit overkill. that will grab very aggressively. an mx6/probe stage 2 will do just fine unless you are planning on making this strictly a track car and doing a lot of power mods to it. just my .02, but congrats on getting the motor put in. let us know how it all turns out.<p>[ July 26, 2002: Message edited by: cre8v mx3 ]
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
Re: klze finally :)
thanks for the input cre8v mx3, you see I've never driven a stage 2 or 3 clutch, all i know is 3 is just about as good as you can get without losing street driveability....I hope Im right...I dont want an on/off clutch
<P>as for power mods...who knows at this point...
Tom Alexander
Re: klze finally :)
are you getting the clutch that a-spec makes
Re: klze finally :)
thats what I was planning on...<BR>but I think I need to do a little more research...<P>Do you know exactly what the clutch is that they make. I know its a 6puck copper clutch.
Tom Alexander
Re: klze finally :)
Tom, <BR> I did my swap at A-spec, I'm very happy with it. They did a great job. I recommend them.
George <BR>92 GS-R 2.5 KL-ZE
Re: klze finally :)
I'd stay away from copper puck clutches. Very grippy, to the point of destroying more than one G25M-R tranny that I've seen...<P>Go with a full faced organic disc and a heavy pressure plate if you want a grippy streetable clutch. Alot less chatter, longer tranny life. <A HREF="http://www.advancedclutch.com" TARGET=_blank>www.advancedclutch.com</A> Get the kit for a MX-6 V6
David Coleman
Re: klze finally :)
thanks dave,<BR>I think I am going to trust you on this one and go with the act.<P>You guys rock...
Tom Alexander
Re: klze finally :)
what about clutch masters stage 2
"A hero and a coward both feel fear but it is the hero who reacts first while the coward hides behind the hero"
Re: klze finally :)
im not positive but I think that the parts dave mentioned are a stage 2 setup. Am I right?
Tom Alexander
Re: klze finally :)
The clutchmasters stage 3 is equivalent to an ACT stage 2. If you search this forum for ACT you'll find all the part numbers you need.
David Coleman
Re: klze finally :)
<A HREF="http://www.advancedclutch.com/v3/appsfr ... asp?ID=161" TARGET=_blank>http://www.advancedclutch.com/v3/appsfr ... ?ID=161</A>
David Coleman
