Keyless Entry
Keyless Entry
Im thinking about getting keyless entry installed on my car. I have already have a remote starter (canadian tire/not installed yet) and it has a second button on it for power locks. I was wondering if it can be programed to work with the locks im about to get put on. Also, at the moment, my car doesnt have power anything. How much trouble will it be to put the keyless entry (at least on driver door) and how much should i expect to pay at a local shop. Any info on this would be great. Thanks<p>Jeff
Re: Keyless Entry
Well, if you already had power locks then a couple hundred would get you keyless installed. Without power, I can only guess, but I'd say around five hundred(?). <p>I'd ask the installer/dealer about a unit compatible with your remote starter if you want to be sure to avoid two separate "detonators" on your keychain ....
Re: Keyless Entry
$500???
Try under $100 to get power door locks
93 GS, KLZE, KL31 ECU, Centerforce Stg 3 Clutch, 2.25" Exhaust w/Flowmaster muffler, OBX Headers, Pheno Spacers, Front & rear X-drilled/slotted Rotors, KVR pads, SS brake & clutch lines, Ractive Filter, H&R Springs, Tokico Blue Struts, 8mm Accel Wires, MSD 6A w/ Blaster 2 Coil, HVAC Indiglo Panel. *Sold*
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
Re: Keyless Entry
yea you can get a system for like $50 and two actuators for 10 a piece on www.partsexpress.com
Shaun Newman
Re: Keyless Entry
$500 maybe a bit much ...lol, but he says he is considering having it installed, if you do it yourself that's a different story ... ![Smile :)](./images/smilies/icon_smile.gif)
- airjordon_09
Re: Keyless Entry
Mazda in Ontario will do it for 80-90 a door depends on who you talk to<p> peace
