exhaust
exhaust
Would it be possible to put the Corksport exhaust on? It has a 2.5" inlet and 3.5" outlet. I'm pretty sure the inlet is too big, but is there like an amplifier you can get for the pipe to make it fit? If so, how much $? Thanks.
Re: exhaust
Put which Corksport exhaust on what? Why not call Corksport and ask them?
Re: exhaust
I called Corksport and the guy said it should fit, but said he wasn't completely sure. It's Corksport's stainless steel muffler with a 2.5" inlet and 3" outlet (I said 3.5" before, I was wrong). I just want to know if I would have to get custom piping done and if so, how much it would cost. Also, would there be a problem with backpressure?
