klze ecu
- Buff1110
klze ecu
now i know in 96 with kl03 at least the o2 sensors are different therefore u must use an ecu from like a 94, now the klze, is this the same situation or can u use the ecu from a newer ze?<BR>Dan
Dan
92 Mx-3 Gs, KLZE Powered!! - SOLD!!!!
02 Tacoma TRD - Daily
93 Honda del Sol - New Project
Re: klze ecu
I don't know for sure but to be on the safe side I would use one from the same model year (or close to it) as your car.<P>The 96 US car with pre-cats and OBDII shouldn't apply to JDM cars.
