Oil infiltrates in spark...
Can you help me ?<BR>Oil infiltrates in the tube where are the spark and their wire... <BR>Have You already heard about this kind of disorders and what can be the solution... <BR>It seems that its the gaskets (O ring) of the valve cover<BR>is it necessary to remove the intake to change those of the rear rolls?<BR>Can i roll without repairing them? <BR>If you have a solution contact me [img]shrug.gif"%20border="0[/img]
Re: Oil infiltrates in spark...
It's the valve cover gaskets. You will have to remove the intake manifold to get to the rear valve cover.
David Coleman
Thanks<P>Can i roll a little bit before repair them ?
I've been going a while with the problem. just clean out the oil every month or so and keep the oil level correct. I'm planning on doing the fix this summer. You have to remove the intake to get to the back cover.
I have the same problem, and im just wondering if its serious or not..<BR>i've left my car like this for year.. so far nothing horrible has happened, except that annoying knocking sound on cold starts.. would that be related to oil in the spark plug wells?
Deano, 1996 Black GS<BR>http://members.shaw.ca/mx-three
- Zoso124
No its not that serious. You may just have to change plugs a little sooner that usuall.
Mike Evans
Gone:
Gone:
