Loose Rotors
Loose Rotors
I was changing my brakes the other day and noticed that when I took the old brakes off that the Rotors just slide off. What is supposed to hold them in there. Autozone told me that they were supposed to be like that and that my rims will tighten everything up when I put my wheel back on. Does anyone have the same thing? Thanks
Jason
Re: Loose Rotors
There's supposed to be a screw that holds the rotor on (look for a recessed hole in the hub) but these get rusted in place and the screws get broken off. Like Barry said the wheels hold them on so there's no need to replace this screw.
Re: Loose Rotors
no screws on the front just the back
