engine power loss
engine power loss
Has anyone had power loss or fuel pressure loss while turning right? This happens when I have 1/4 TO 1/8 tank of gas. Am I moving the fuel away from the pick-up in the tank?
Re: engine power loss
yes.<P>------------------<BR>David Coleman- <B><I>Moderator</B></I><BR><A HREF="http://www.PinkMX-3.com" TARGET=_blank>1993 Mazda MX-3 GS Special Edition</A><BR><B><I>Why get clear tail lights when only Geo Metros are gonna see them?</I></B>
David Coleman
Anybody ever put a fuel cell in an MX-3?
Thanks I wasn't sure that my friend was correct.
You sure you really had a 1/4 tank? When i repositioned my needles after my SRD gauges, i realized how off they were set from stock. This also happened with 2 of my freinds mx-3s...they're gas light would be on, and the needle would still read about 1/8...weird....by the way my gauges used to read, i thought i had about a 10 gallon tank, because when i filled it up from what i thought was empty, it took about 9.2 gallons. Then I read somewhere that it actually has a 13 gallon tank? That's how I knew my gauges were way off<P>------------------<BR>~'94 GS
