Help with Eunos Presso Transmission
handbrake2
Hi,<BR>I'm from Barbados and I have a 1994 Presso 1.8 V6 that I bought used from Japan. I have to replace the transmission and I can't find 1 locally. It would be significantly cheaper if I could buy 1 in North America and get it shipped here instead of ordering 1 from Japan. My question is do the parts from an MX3 1.8 V6 fit the Presso, especially the transmission?<P>Thanks and regards,<BR>Handbrake2.
David Coleman
Re: Help with Eunos Presso Transmission
automatic or manual?
David Coleman
handbrake2
Thanks for responding.<BR>It's automatic. <P>Handbrakle2.
David Coleman
Yes. You could also use an automatic transmission from a MX-6 V6 or Ford Probe GT V6 [93-97] with some adaptation.
David Coleman
handbrake2
Adaptation sounds bad. Would an MX3 transmission be a direct swap, or can I buy a Eunos transmission directly in the States?<P>Regards,<BR>Handbrake2.
David Coleman
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by handbrake2:<BR><STRONG>Adaptation sounds bad. Would an MX3 transmission be a direct swap, or can I buy a Eunos transmission directly in the States?<P>Regards,<BR>Handbrake2.</STRONG><HR></BLOCKQUOTE><P>Mazda = Eunos. So the gearbox from the MX-3 GS would be identical to one from a Presso 30x V6.
David Coleman
handbrake2
