For those of you with a GS and an amp....
Where do you run the amp power line through the firewall? Is there some small hole that i cant see or something?
My Cardomain site
My Cardomain site
Re: For those of you with a GS and an amp....
its not really a hole, but its kinda like a plug that covers the hole, so you need to push it out somehow and put the power wire thru it, then set it back into place.. im pretty sure thats how i had mine done, i just got a friend to install my system. you should be able to see this "plug" like thing from the engine bay. lates
![Image](http://i5.photobucket.com/albums/y181/hitz1035/s510595978_1374896_9416-1.jpg)
'92 Intense blue pearl Jeep YJ, OME lift, mudders, fun.
R.I.P.
'93 Clear white GS-DE ~14.648@92.98mph, 2.234 60ft. PARTING OUT PM ME.
- Wildman640
i ran mine just like thebonestockkid said in the previous post. Do it that way and you should have no problems
- monty73741
there is a grommet right behind the battery on the rs......if you can see it on the gs you be able to get it through....
jason
jason
Jason Danaher
Please Help Support MX-3.com
On the GS mine at least there is a big *** hole on the passenger side of the vechile, if you wanna run it all the way across it was really easy to put in no cuttin or anything. Look for it.<p>BTW I have a 93 GS
with an auto u can put it through a square hole locate right behind the bar the gas pedle is connected to
Thanks for the replys...I took a look this morning when it was light(last night it was dark as a mofo) and found that little plug/hole, should work out perfectly...also, I want to see what you all think of my plan....I want to bolt my amp for my subs onto the sub box, and run the RCA wire along the driver side under the little side runner thing and so on, and i want to run my power along the passenger side..sound good? And my amp for my regular speakers i want to put under my passenger seat, run my power wire for that one right next to the other one, run it under the carpet and into the amp...and i want to put the RCA cables right near the shifter, under the carpet, and into the amp...what do you all think?? Oh yeah, i took my subs in with the spec sheet to a local audio shop,and theyer building me a box that is meant just for my subs...im going to be picking it up on friday...Ill keep you all posted...
My Cardomain site
My Cardomain site
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by mx3man83:
Thanks for the replys...I took a look this morning when it was light(last night it was dark as a mofo) and found that little plug/hole, should work out perfectly...also, I want to see what you all think of my plan....I want to bolt my amp for my subs onto the sub box, and run the RCA wire along the driver side under the little side runner thing and so on, and i want to run my power along the passenger side..sound good? And my amp for my regular speakers i want to put under my passenger seat, run my power wire for that one right next to the other one, run it under the carpet and into the amp...and i want to put the RCA cables right near the shifter, under the carpet, and into the amp...what do you all think?? Oh yeah, i took my subs in with the spec sheet to a local audio shop,and they're building me a box that is meant just for my subs...im going to be picking it up on friday...Ill keep you all posted...<hr></blockquote>
My Cardomain site
My Cardomain site
just make sure u run both power cables on the same side and both rcas on the opposite side
i ran mine like the bonestalk kid but instead of just popping it out i drilled a hole into then ran the wire, then sealed the wires with sillicon (sp)
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
