Subs keep blowing fuses?
I have 2 12" Rockford subs with a 600WT amp. I had it installed at Best Buy and it worked fine, hit hard with no problems. I took it out for weight purposes then put it back in. Now everytime it gets half-way loud, a fuse blows. It's done it about 4 times now in the last few days? Any idea what's causing it? I must have hook it back up wrong but I can't see any problems with it. <P>Thanks.
Re: Subs keep blowing fuses?
are you using the same wires? Are you using the same ground point? Try changing to a highter rated fuse?
Shaun Newman
Everything is the same as it was when it was first installed. It's wierd...
What size fuse did they give you? THEY might have hooked it up wrong.... lol, they do that a lot.
FOR SALE, AS A PARTS CAR
1994 Mazda MX-3 <-- 152dB's w/ 1 15
> Invited to '02 USACi World Finals, but did not compete due to stock alternator problems.
> Can't go to '03 USACi World Finals because I HAVE NOTHING LEFT!!
15 It worked just fine before i took it out.
WOAH!!! 15 amp for a 600 watt amp? that ain't right bro. look at what fuses are built into the amp, total them up, and stick that (or slightly lower) in the fuseholder under the hood
You should probably be running a 25-30 amp fuse with that setup. Try switching
Shaun Newman
i have a 30 in my amp, and a 30 under my hood. they work fine and havent blown yet. if i were you i would try that.
RIP 95 rs
