Shaved Antennae
Shaved Antennae
Hey, I know some of you out there have shaved your antennaes and I want to know what kind of reception you get now. Do the FM signal boosters work well? I am really interested in shaving it, but I don't want to loose reception. Is there an internal antennae that I can get that will work? I know that the 1999 accord doesn't have an external antennae but it gets really good reception. I was just wondering about it. Thanks
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
- Andrew_Pakula
Re: Shaved Antennae
The best person to ask is Tom S. (percidian) on the boards here. He has his antenna shaved off and has an internal antenna that sticks across the top of the windshield, it's quite cool!
Re: Shaved Antennae
to let you know, when i first got my mx-3 i had some rust spots on the top of the car and i decided to just get rid of the antenna and have it shaved. I also have an external antenna that goes across the top of my windshield, you get about the same reception. It also cost about $175 dollars to fill the hole, and what not. hope that answers your question
Re: Shaved Antennae
175 to fill the hole?!? wow, that seems a bit high, i'll buy some bondo and do it myself, thank-you-very-much, lol
- Andrew_Pakula
Re: Shaved Antennae
$175 seems a bit expensive(and I am assuming that is American dollars since you are from minnesota).<P>When I got my Top-mix GTR wing installed they had to weld over the two holes left behind from my old spoiler, that only costed like an extra $100 Canadian mostly because they had to take the glass off first.
Re: Shaved Antennae
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by matt satzinger:<BR><STRONG>to let you know, when i first got my mx-3 i had some rust spots on the top of the car and i decided to just get rid of the antenna and have it shaved. I also have an external antenna that goes across the top of my windshield, you get about the same reception. It also cost about $175 dollars to fill the hole, and what not. hope that answers your question</STRONG><HR></BLOCKQUOTE><P>$175? you got your a--hole ripped open on that deal bro. Luckily I do my own fiberglass body work. I don't want ANY visible antenna. I just want an internal antenna that will give me close to same reception. If I have to get an FM booster so be it. I don't want to see the antenna at all. Any other options?<P>Thanks
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
Re: Shaved Antennae
Hehe what you even need an antena for anyways I mean seriously how often do you guys actually listen to the radio LOL
Re: Shaved Antennae
Actually in my MX-3 I listen to it all the time. I never used to but I recently found a station that kicks a-- (hard to find in Utah)
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
Re: Shaved Antennae
Oh hehe, well I know that I always got my cd player going, I make my own cds rather than have to listen to shitty songs on normal cds. I am good at mixing up tracks and s--- and making a good flowing cd, well that and with a 10-disc cd changer shuffle works wonders
Re: Shaved Antennae
is having the antenna "in" the same as not having one ?? if so the reception sucks.
Re: Shaved Antennae
no.. its not the same whatsoever.<P>The original question is if the antenna is Shaved off,( a.k.a completely taken out and the remaining hole in the body welded shut and painted over...), would the reception of the radio remain the same.<P>The internal antenna, is like a strip that goes across the inside of the windshield.<P>i want one pretty bad, Andrew wants one worse though
Calen Sansom
1994 MX-3 GS Sparkle Green
Re: Shaved Antennae
i had that strip ant. in my old accord the recepition was better than my old one and it only cost me like $10 butt i ran the wires like s---, anyway what if you put the ant. down and got a fm booster that should more than make up for the ant being down right?
http://members.cardomain.com/anjin1982
Maintaining my MX-3 in it's natural beauty state...Although i love the modded one's!!!
Re: Shaved Antennae
Well it's a little more complicated than using a booster to amplify a weak signal when your ant is down.<BR>It's somewhat difficult to boost the signal to noise ratio, so although the signal might be strong enough, there may just be too much noise. My guess is that this will probably work with a windshield antenna in a satisfactory manner, as long as you currently don't have reception issues.<P>The primary downfall of winsheild antennas is that they are somewhat directional. For optimum performance the antenna should be orthoganal (right angle) to the direction of the source. The stock antenna have a somewhat vertical slant to provide this. You could maybe make a windshield dipole, but I doubt it's necissary.<P>All in all I'd say go for it, looks will more than makeup for somewhat worse reception, especially if you mostly listen to tapes/CDs!<BR>Good Luck!
tk1138<P>There's not really anything I want to say over and over.
Re: Shaved Antennae
I don't use my radio much at all.. I like this strip antennae idea... I might have to get a quote on that being shaved off.
FOR SALE, AS A PARTS CAR
1994 Mazda MX-3 <-- 152dB's w/ 1 15
> Invited to '02 USACi World Finals, but did not compete due to stock alternator problems.
> Can't go to '03 USACi World Finals because I HAVE NOTHING LEFT!!
Re: Shaved Antennae
just get xm radio them u can have a MX3XM
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
