Fixing My Sub
Car Stereo/Alarm Discussions
Jutzi420
Fixing My Sub
Post by Jutzi420 »
I've got a couple of JL 10w3s, and on one of them a lead has come loose from where it was glued to the cone. It makes a really loud rattle at loud volumes, any suggestions on what type of glue I should use to fix it?
mzdspd
Re: Fixing My Sub
Post by mzdspd »
i have had this same problem with opther subs. i couldn't find anything that could permenantly fix it but if u use the clay thats used for sealing stuff you can get it at ace hardware for like 3 bucks a role and just stick some of that on their it will last for like another 3 months
monty73741
Re: Fixing My Sub
Post by monty73741 »
wouldnt that be a product defect & be a warranty item<BR>jason
Jason Danaher
Please Help Support MX-3.com
Jutzi420
Re: Fixing My Sub
Post by Jutzi420 »
It would be, but I got the subs with the car when I bought it. So that's a no go.<BR>I've got some electrical tape in the right now that's doing the trick, but it won't last.
RaspMetalicMX3SE
Re: Fixing My Sub
Post by RaspMetalicMX3SE »
try some stuff called GOOP It's as strong as super glue you can get it any hardware store or walmart target ect. I used it to put on my mesh for my bumper it works awesome just takes a while to dry
Shades
Re: Fixing My Sub
Post by Shades »
Screw the GOOP... go with Epoxy... strong as SHHHH...
"Do it ONCE, do it RIGHT!"
Guest
Re: Fixing My Sub
Post by Guest »
shades is right an epoxy or a hard urethane
Jutzi420
Re: Fixing My Sub
Post by Jutzi420 »
Thanks guys I'll give it a shot tommorow.
Return to “Car Stereo/Alarm”
