Fixing My Sub
Fixing My Sub
I've got a couple of JL 10w3s, and on one of them a lead has come loose from where it was glued to the cone. It makes a really loud rattle at loud volumes, any suggestions on what type of glue I should use to fix it?
Re: Fixing My Sub
i have had this same problem with opther subs. i couldn't find anything that could permenantly fix it but if u use the clay thats used for sealing stuff you can get it at ace hardware for like 3 bucks a role and just stick some of that on their it will last for like another 3 months
- monty73741
Re: Fixing My Sub
wouldnt that be a product defect & be a warranty item<BR>jason
Jason Danaher
Please Help Support MX-3.com
Re: Fixing My Sub
It would be, but I got the subs with the car when I bought it. So that's a no go.<BR>I've got some electrical tape in the right now that's doing the trick, but it won't last.
Re: Fixing My Sub
try some stuff called GOOP It's as strong as super glue you can get it any hardware store or walmart target ect. I used it to put on my mesh for my bumper it works awesome just takes a while to dry
- Shades
Re: Fixing My Sub
Screw the GOOP... go with Epoxy... strong as SHHHH...
![Image](http://i491.photobucket.com/albums/rr275/Spudsicles/BannerFx.jpg)
"Do it ONCE, do it RIGHT!"
Re: Fixing My Sub
Thanks guys I'll give it a shot tommorow.
