LUCUS (WAS)..pat me on the back...
Off-Topic Discussions
Ehpl
Re: LUCUS (WAS)..pat me on the back...
Post by Ehpl »
I have a 1.6dohc, when at the dealer the other day I asked the same question they said 2.7L.
I hope they are right , cause thats what I put in.
As for the idle problem put a block off plate on your egr port, I did an now I have no idle problem , I think they get stuck when they get older.
Eugene L
1.6DOHC
N.S.canada
http://www.cardomain.com/memberpage/552384
johnnyb
Post by johnnyb »
for a 4 cyl man tranny you need 2.68 liters or 2.83 qts
for A 6 cyl man tranny you need 2.7 liters or 2.9 qts
mx3man83
Post by mx3man83 »
Originally posted by perhapsadingo8yerbaby:
I've checked the research, talked a lot with the owner as well as use his products and he is a totally anal fanatic (my kind of guy) about lubricants/additives etc.
Sounds kind of weird to me....but anyway, I have the lucas stuff mixed with redline 75 90 in my tranny and it shifts way better than when I had just redline 75 90 in it. My 2nd to 3rd gear syncro is jacked up too. This helps it out tremendously.
My Cardomain site
Post by perhapsadingo8yerbaby »
Good one mx3man! :roll: damn, hate it when that happens...
<small>[ July 07, 2004, 01:13 PM: Message edited by: perhapsadingo8yerbaby ]</small>
Return to “Off-Topic”
