94 mazda mx3 - 1.6L, 5speed - driver side axle problem
Posted: June 6th, 2016, 8:42 am
by pdoan_98
The driver side axle is "stuck" on the inside connection. My local mechanical spent a couple of hours trying to uninstall the axle to no avail. Any ideas?
Re: 94 mazda mx3 - 1.6L, 5speed - driver side axle problem
Posted: May 8th, 2017, 10:10 am
by Demonic1
Hi!
So, there's a spring clip that sits on the axle that holds it inside the transmission (part #1 in the manual link below). There are many methods that people say get these things out.
http://www.mx-3.com/manuals/showimg.php ... _M-028.gif
Here's a few thread from the forum on the issue. They should give you some ideas.
http://mx-3.com/phpBB3/viewtopic.php?f= ... it=circlip
Posted: May 8th, 2017, 9:19 pm
by Daninski
There is an axle puller you can probably rent it. I used one and the axles just popped out.
Posted: May 16th, 2017, 9:51 am
by mitmaks
I used giant wheel/tire iron and wedged it between axle and transmission and pulled on it, axle popped right out.
Posted: May 19th, 2017, 12:12 am
by Daninski
mitmaks wrote:I used giant wheel/tire iron and wedged it between axle and transmission and pulled on it, axle popped right out.
I love it when you talk dirty
