KLDE transmission sensors
So I recently did a KLDE swap to my GS. the only problem I have is figuring out where the transmission sensors plug up? I basically have everything working except my reverse lights and speedo...not sure if that would be the same sensor, but theres no where I can see on the MX3 harness to hook them up to
1993 MX-3 w/ straight neck KLZE swap...Probe GT 2.5in headers, Custom exhaust w/ test pipe and OBX Twin Loop Tip, Bully Stage 3 Clutch, Fidanza Flywheel, Pheno Spacers, HEI mod, Blaster SS coil, Probinator chip, TWM short shifter, AWR front and rear mounts (88 Durometer), and Corksport braided clutch line...so far
Ever see the lone rider of the night? Well he'll find you and then you'll never him again...
Re: KLDE transmission sensors
You didn't keep your Mx-3 trans? What trans did you put in?
You need to use your speedo sensor from your MX-3 transmission. You might have a later year transmission which uses a different speedo sensor.
The reverse lights and the neutral safety switch look similar. One bolts on the front of the transmission near the oil fill plug, and the other is on the rear of the trans where the passenger halfshaft goes in the trans.
Correctly referenced as the neutral switch. Neutral safety switch is on the automatic trans.SuperK wrote: The reverse lights and the neutral safety switch look similar.
Here is the trans and the itemized index is on the next page. Good luck
Appears dan forgot to add the links. If you have not found what you needed in the service manuals then the links below should help.
Diagram of transmission showing location of the neutral switch and back up light switch:
link to transmission diagram
Neutral switch trouble shooting and possibly a better diagram in service manual section F:
link to neutral switch
For the location and diagram of the speed sensor:
link to speed sensor
Opps sorry the link was there cuz I had the page address copied. Whatever
Don't forget the washer for the reverse switch.
