Using A Power Steering Pump To Supply A Remote Mount Turbo
Posted: June 10th, 2014, 7:32 pm
by posey92
Simple as that. Saw a quad turbo 454 that used a power steering pump to pull and push oil to the 4 turbos...so instead of using an expensive $300+ oil pump to pump oil to the turbo and and back...its already good for the hi heat and volume to move...its mechanical so less likly to fail and its alot cheaper to do that...if ur doing a ps delete its already there.....
Re: Using A Power Steering Pump To Supply A Remote Mount Tur
Posted: June 11th, 2014, 10:34 am
by RogueWolf
I'm not sure if that blurs the line between Genius and Crazy...
Posted: June 11th, 2014, 11:20 am
by posey92
Im leaning towards genius.later I'll look into it more and post more info.got a turbo and stuff last night
Posted: June 12th, 2014, 10:47 pm
by posey92
So ill be doing this soon. I have a turbo and gauges I'll be remote mounting
The turbo where the cat is.then using a closed oilsystem itll go ps pump to turbo to an oil cooler thru the pump and do on.
Posted: June 13th, 2014, 9:47 pm
by zerialz
This is some mad scientist s--- right here.
Posted: June 14th, 2014, 4:03 am
by posey92
It will be when I'm done...
