Hey guys it's been a while, I need some help. Under the dash on the drivers side behind the fuse box there is a 6 pin white connector that I cant seem to find where/if it plugs in to anything. its connected to the wiring harness that runs into the relays behind the fuse box. The colour on the connectors are. it's a 94 mx3
Red
Green/Pink
Green/Red
Green/Orange
White/Green
Black/Pink
it's not long enough to hook into the fuse box if it could, nor is it long enough to go up to the dash. I honestly cannot remember if I even unhooked it.. It's down by the clutch left side.
Connector under dash
- mazdaspeed23
Own
1994 MX-3 GS swapped ZE
1994 MX-3 GS Swapped ZE (Gone)
1996 Dodge Dakota Sport v8 Magnum
2007 Ford Fusion SE
WORK LOG: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=81232
![Image](http://i1187.photobucket.com/albums/z397/moneyshot23/rsz_1994155_10152926217650640_511810948_n_zps966fe00a.jpg)
My MX-3 is nothing without me, and i am nothing without my MX-3
2007 Ford Fusion SE
Re: Connector under dash
Hey there, I might be able to help. I have a 94 gs 1.8L and I just swapped out all relays and fuse block so I'll take a look today, I also have a few wiring schematics of the fuse block and also which plug is which that goes to it. I'm still trying to figure out the picture posting but I should have em up in a day or two.
- mazdaspeed23
hey thanks for the help. You can send the pictures to my email it'll be faster moneyshot23@kos.net
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
Sent you an email with schematics and a pick of my relay's under the dash, hope that helps.
- mazdaspeed23
Thanks for the help.
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
