Before a few months i made a bp swap.The vaf is holded with tire ups cause there is no room for the bolts.
When i move the vaf to a complete parallel position with the ground the rpm goes down and then the engine shut down.
When i leave it in the first position,which a little angle position to the ground,everything is normal.When i move it the engine goes off
I have no leak on the intake and the wire connection is fine..
Any ideas?
Engine shut downs when moving vaf
- DeadMaker
Black Mazda Mx3 Rs 1997 B6DE
- MX_Sid
Re: Engine shut downs when moving vaf
It could be weak or broken spring inside, stop by the junkyard and pull one off a protégé lx or maybe an escort gt. If the problem persists, check for corrosion somewhere... That's where I would start.
I HATE mechanic shops and LOVE junkyards!!
