Looking for some suggestions
Posted: March 7th, 2014, 12:50 am
My winter beater has developed an odd issue over the past few months...
Initially, it was the starter that was a bit wonky. Solenoid would fire but starter wouldn't turn, so I dismissed it as a bad contact in the solenoid. If you re-started it over and over eventually it would take. (clunk clunk clunk clunk vroom)
Then that stopped working, but I could start it under the hood with a screwdriver across the starter terminals.
Now it doesn't have ignition at all, and turning the key to 'start' has no effect whatsoever. You can still get it to crank via screwdriver, but no spark.
Tried disty, starter is mechanically fine, thinking harness, grounds, or ECU is next... anyone have any similar experience?
I guess I should mention its a 93? ATX with a 92? KLDE MTX swap.
