Front shifter link fix/mod
Posted: June 15th, 2013, 1:42 pm
by Tavman_1213
So Mi|<e an I were both having the same issue of the front shifter link having the same issue where you would tighten it all the way an you would still have some play in the shifter. So we found in my bolt bin a couple of 14mm transmission bolts an we made a flat edge on the top to fit with the linkage. Next we drill out the bottom of the linkage to allow the bolt to go through completely. Found a nut to make our new shifter linkage bolt, tightened it down(you can go pretty tight on this one cause its only the one under the shifter that has to pivot). And Walla no more shifter play(if the other is tightened up with lock tight). I havent driven my car since doing this mod but Mi|<e says its the best mod you can do for drivability!!
Do this at your own risk but I think it's a great mod for a flawed design!
Re: Front shifter link fix/mod
Posted: June 15th, 2013, 2:04 pm
by Daninski
Not exactly sure what you mean, can you elaborate a little for my illiterate self.
That bolt goes through the front shifter linkage at the trans isn't it? Is that where you experienced excessive tolerance.
Posted: June 15th, 2013, 2:29 pm
by Tavman_1213
Yes it is the front bolt that goes through the transmission. So with this new design you can tighten it up an take all the slack out of the linkage. It also can not be over tightened like the one that attaches to the shifter because it does not pivot or move.
So the stock bolt you are unable to tighten it down completely because it hits the bottom of the shifter linkage cause of the design of the bolt. As you can see there is very limited threads an you can never tighten it down because the bolt bottoms out before all the play is taken out of the linkage. This is why we took a regular bolt(one that just fits through the bushings) and notched it at the top so that you would not have to change the shifter linkage.
Posted: June 15th, 2013, 3:39 pm
by [LVPA]93GsSe
I like the sound of this, would like to hear what you think of it when you drive it.
Posted: June 15th, 2013, 4:54 pm
by Evo_Spec
awesome discovery, i've been having issues with this myself.
Posted: June 16th, 2013, 2:53 pm
by MrMazda92
I did this as well, but didn't really explain when I made my original thread about shifter play...
I have about 1/16" lateral play in my shifter, and I love the hell out of it. It does vibrate far more than stock though... I think mine has the worst shudder/shake to it that I've ever felt...
Totally worth it though!! Thanks for sharing the idea!
Posted: June 16th, 2013, 8:21 pm
by Daninski
Hmm, I never noticed any play in mine but then I probably wan't looking for it. So we should experience less side to side (lateral) slop in our shifters with this fix. I hate the lateral play in my shifter.
