Page 1 of 2
Brake lines that are stuck
Posted: May 20th, 2013, 3:29 pm
by WhiteFinish
So who has some tips to get this loose?
These things have a 10mm wrench, but they are so stuck that the wrench slips over it and rounds the edges.
Re: Brake lines that are stuck
Posted: May 20th, 2013, 3:38 pm
by youdirtyfox
Posted: May 20th, 2013, 4:28 pm
by Josh
At this point It looks like you need a pair of vicegrips...
Posted: May 20th, 2013, 4:59 pm
by Evo_Spec
Josh wrote:At this point It looks like you need a pair of vicegrips...
+1
That's what i did with the bleeder screws, just put on some vicegrips so tight that you pretty much need to do it with pliers just to get the vice grip on.
Posted: May 20th, 2013, 5:08 pm
by WhiteFinish
What is a brake line spanner? How is it different from a regular wrench?
Posted: May 20th, 2013, 6:50 pm
by marcdh
Has only one open end
Posted: May 20th, 2013, 10:58 pm
by wytbishop
Called a flare nut wrench here.
Heating the distribution block that they are screwed into will help.
Posted: May 21st, 2013, 1:34 pm
by Silkwyrm
Ah you English and your funny.. English.
Disclaimer:
Those of you not in England, I apologize if the reference offends you. But the linguistic joke doesn't work with the word Brits, or United Kingdomers, err whatever.
Posted: May 21st, 2013, 4:40 pm
by MrMazda92
Are you asking about the brake lines themselves, or where they mount to the subframe?
If it's the subframe, grind the edges super flat and use an adjustable crescent style wrench to hurk it off.
Posted: May 21st, 2013, 7:17 pm
by Evo_Spec
MrMazda92 wrote:Are you asking about the brake lines themselves, or where they mount to the subframe?
he's talking about the brake lines themselves, if you look at his picture the threads on the brake lines are stripped.
Posted: May 21st, 2013, 8:26 pm
by mitmaks
Should've tried soaking them with penetrating fluid like PB Blaster or WD40
Posted: May 22nd, 2013, 6:51 pm
by MrMazda92
In that case...
Torch + Vicegrip pliers. Replace with factory hardware from a different car, use anti-seize in the future...
Posted: May 23rd, 2013, 1:42 pm
by WhiteFinish
With some vice grips I've got them loose.
Don't know how to reapply them because it got stripped.
Posted: May 23rd, 2013, 3:28 pm
by Josh
WhiteFinish wrote:With some vice grips I've got them loose.
With vice grips
Posted: May 23rd, 2013, 4:25 pm
by WhiteFinish
Hahaha...
I mean, it isn't possible to change the stripped part ?
