replacement speakers
- mitmaks
I'd like to upgrade speakers in mx-3. 20 year old speakers don't sound good anymore. Which speakers will bolt right in (for the back and doors)
- Surgeonasst222
Re: replacement speakers
6.5 I believe... The holes might not line right up... But pretty dam close! If u want I can sell u my stocks?
There in good shape, but I would recommend aftermarket ones...
Mazda3 2012 - my NEW DD
Mazda MX-3 RS 1992 - my project
Ford Focus SE 2010 - sold
Ford Focus SE 2003 - sold
Mazda MX-3 RS 1994 - sold
They're 6.5" front and back.
Watch the mounting holes though. AFAIK they used the 3 hole mounting layout for all of our cars. I ended up going with the Kicker setup for my 92. They were the only brand at the stereo place with 3-hole in them.
I don't regret these speakers at all.
92 RS BP05
93 GS KLZE
92 RS BP05
93 GS KLZE
The sticky thread right above this one isn't of any help?
http://mx-3.com/phpBB3/viewtopic.php?f=8&t=45443
- Josh
6.5" for sure just doing mine. I drilled new holes in my rear speakers for the mounting holes. If you do not use the plastic mounts in the front doors they will ground out and when it rains,... well, they quit working..
If you are not as adventurous as I you can order up some Scosche adapter rings, they are like 10 bucks a set. They were available on Amazon a while back for the MX at like 8 dollars.
If you have a hairdryer I also recommend taking the plastic backing plate off of the OE speakers. This helps throw the sound into the car as well as it keeps water from dripping down the window to the back of the cone.
