Just checking out some rims
Wanting to know if 17 x 8 with an ET +20
with a KYB Exel /50mm lowered springs combo would fit without any issues?
Or would I have to run coilovers?
Also any suggestions on tire specs?
Thanks Y'all
Will they fit 17x8 ET +20
Re: Will they fit 17x8 ET +20
I don't think it would be problematic with the strut but you might have to roll your fenders to make it fit.
- AaronTietje
I think they should fit. I have coilovers with 8in wide rims and a 15 offset in the rear. I probably have an inch between my rim and coilovers, but I did have to do mild fender rolling.
Depends what size tire you are planning on fitting? that also may affect weather you actually need a fender roll being @ -50mm
Thanks guys that gives me a bit of direction, cheers for your expertise
i just installed 17x8 ET 40 with 235/40 tires and thats about the biggest you can go with coilovers and no roling fenders.
Black Mx3 GS
ZE swapped with kl36 ecu and Exedy oem clutch, Fidanza flywheel, 2.5" stainless exhaust, Ebay headers, 8mm sparkplug wires and Denso iridium sparkplugs, Rockspeed CAI, 17x8 wheels, 235/40 Goodyear eagle f1 as, Taroc japan sport discs and pads.
good to know man, Im thinking of running 215/40 tire with the above mentioned rims
