Overheat Problem
Posted: March 27th, 2013, 1:51 am
by colt45
My mx3 overheats sometimes for only a minute and then goes back to normal. Sometimes the heat shuts off too as well as the occasional engine light.
There is also a burning plastic smell if that's related at all?
*1994 Mx3 gs, v6 1.8L
Any help would be great!
Thanks!
Re: Overheat Problem
Posted: May 26th, 2013, 6:32 pm
by wednesdayslatest
im for sure its the thermostate
it really sounds like it v6 or i4 doesnt matter if you turn your heat on even tho it doesnt work then the heat should drop to normal
also i had heating issues too
if the heat goes on and off then its a thermo and maybe you want to flush and put new coolant as well. make sure your headgasket is good still
keep up with oil changes make sure the oil doesnt have coolant in it and makes sure the coolant doesnt have oil in it if the coolant is brown like mine was then you need a new headgasket and do that sooner then later or else youll have to replace the head
also since your looking at it i know its not part of it make sure your valve covers arnt leaking oil leaks can only come from three places valve cover, head gasket, and oil pan gasket
hope this helps you out
the thermo is inside the thermo housing thats two bolts it comes right now i think there might be a sensor on it too mine does but i have a SOHC i had to put a new sensor in it as well my plug for it was no good so i put a female connector crimped it a little to fit the pin and shoved it in, it works fine without the plug as long as the end is on that pin and isint loose then its good
Posted: May 26th, 2013, 9:32 pm
by DRAG323
Ckeck prestone on your rad ?
Thermostat
Posted: May 27th, 2013, 12:01 am
by pattheriault
air bubble in your system?
Posted: May 27th, 2013, 1:54 am
by wednesdayslatest
also your gonna need a thermo housing gasket too, forgot to mention. if you do take out the housing which you most likely will. check for leaks maybe. or check to make sure the radiator isint old because sometimes theyll leak out slowly internally, and bring your level down. you wont even know and there wont be any coolant on the ground or just barely.
Posted: May 29th, 2013, 10:38 pm
by DRAG323
Solve the problem?
