tune up
- MazdaMan1991
Re: tune up
215k miles or kilometers?
and just do the norm plugs, wires, cap, rotor, if u have an auto trans do a fluid flush and filter change, just stick to 10w-30 any brand really its all the same....
My Mazdas
2008 Mazda 3 FS auto - Totaled
1994 Mazda 626 KL 5 spd - sold
2002 Mazda Millenia S - sold
1994 Mazda MX-3 RS 5 spd - bp swapped
My Worklog/Build Thread
My YouTube Page
![Image](http://i1256.photobucket.com/albums/ii487/mazdaman1991/94%20Mazda%20MX-3/IMAG1781_zps1468f3a8ggr_zpsdf88c62c.jpg)
My YouTube Page
Re: tune up
Its a 5speed, and it has 215, xxx miles. And would it be a good idea to get high mileage oil?
Infernal Darkness.
- MazdaMan1991
Re: tune up
maybe, all the difference is is the detergents in it
My Mazdas
My YouTube Page
My YouTube Page
Re: tune up
Depending on how into it you want to get...
You may want to check the timing belt (depending on last change) for wear and tear. If the timing belt hasn't been changed in over 100k miles do the tensioner and pulley too.
If you do your timing belt, check the water pump too. Replace the gasket at least.
New o-rings for your fuel rail. New isolators for the engine side.
Soak the injectors in Seafoam while you have them off.
Valve cover gasket and make sure to clean/put the RTV down at the marked points in the manual.
PCV valve
If you're in a manual check the CV axle seals for leaks.
Check/fill the tranny (if manual)
Get a good look at the CV boots for cracks
Check your ball joints/tie rod ends/sway bar end links
Clean your throttle body
Part 1 http://www.mx-3.com/phpBB3/viewtopic.php?f=3&t=42551
Part 2 http://www.mx-3.com/phpBB3/viewtopic.php?f=3&t=42552
PCV valve
92 RS BP05
93 GS KLZE
92 RS BP05
93 GS KLZE
- MazdaMan1991
Re: tune up
I second thisDemonic1 wrote:Depending on how into it you want to get...
PCV valve
My Mazdas
My YouTube Page
My YouTube Page
- Surgeonasst222
Re: tune up
I have always been told oil is basically all the same you just need to change it when it is due. The biggest thing that is in those high mile oils is that they make your seals swell... Good if they are leaky but you better never go back to normal oil. As such they will stop swelling and then you might be in worst shape then when you started. High mile oil can help and hurt your car, double edge sword...spike876 wrote:Its a 5speed, and it has 215, xxx miles. And would it be a good idea to get high mileage oil?
I would recommend what the bloke said above, fix the main stuff and u might not need that expensive high mile stuff
Mazda3 2012 - my NEW DD
Mazda MX-3 RS 1992 - my project
Ford Focus SE 2010 - sold
Ford Focus SE 2003 - sold
Mazda MX-3 RS 1994 - sold![Sad :(](./images/smilies/icon_sad.gif)
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
- MazdaMan1991
Re: tune up
so basically u need
plugs
wires
oil change
gearbox oil change
rotor
cap
check all seals
check your timing belt and components
check serpentine belts
check radiator hoses
check pcv valve
check vacuum lines
check vics sensors, over time the plastic gets very brittle and the nipples can break easy :/
and your good!![Very Happy :D](./images/smilies/icon_biggrin.gif)
plugs
wires
oil change
gearbox oil change
rotor
cap
check all seals
check pcv valve
check vacuum lines
and your good!
My Mazdas
My YouTube Page
My YouTube Page
Re: tune up
Not sure where you live, I buy all my parts from Rockauto. Great selection and good prices. I live in Canada (obviously) and up here we get taken to the cleaners on every thing we buy so I order from the states. 'Standard auto parts' makes good parts.
