Even with the fan on HIGH, barely any air blows out of the vents.
-All positions work
-No difference whether it is on FRESH or RECIRC
-The fan itself blows like crazy with the fan box to heater box pipe removed
-Fan box to heater box pipe is not plugged
-I can see the HOT/COLD flap moving through the inlet hole to the heater box
-No difference whether it is on HOT or COLD, so the problem isn't likely a plugged heater core
Basically, the blower fan blows a ton of air, but there is a restriction somewhere in the heater box.
I am out of ideas.
![Shocked :shock:](./images/smilies/icon_eek.gif)
Thanks in advance!
