Motor advice
Posted: January 1st, 2013, 9:15 pm
Okay so yesterday noticed that my motor has ablown head gasket.
I already have a DE that I've partially torn down.
I've got push forward and get it finished.
My thought is to tear it down and re-ring and hone the cylinders. New oil pan and remote oil filter and cooler setup, that's all I was gonna do to the bottom end.
As for the heads im gonna have the heads checked by a machine shop and new valve guides installed.
What's my best plan of attack. I'm not confident enough with this motor to do it all myself,but I still can tear the heads and oilpan off...I've already stripped off all the pulleys and belts. Only external piece left is the oil filter and cooler assembly which is a piece of cake.
Of course this happens after I drop almost $800 on megasquirt lol. So obviously I'm looking for the best price. I'm not looking to spend anymore then about $800.
Only things left to purchase are rings, master gasket set and valve guides. I'm only looking for the bare essentials at the moment. I can do the fun power adding later.
A guy on the boards has klze pistons and rods with new rings....so I am considering bumping the compression for a Lil extra power.
