I've been thinking about this for a while, and I figure it's about time I gave it a shot. I figure if I may end up hating it, I'd rather hate it on a junkyard hood that costs next to nothing, so I'll test it out before I shell out for CF/FG.
Are there many clean examples of MX-3s with functional hood scoops? I've been looking for a while, and haven't found many functional ones at all... IIRC, a few of the U.K. MX-3ers have some, but I have been unable to find pictures so far.
I'd like a low profile scoop, with the entry roughly 1/3 of the way back(3" in front of the IM), and no taller than 1.25" please... If you can find anything that matches that, PLEASE let me know!
Maks,
That's VERY close to what I'm looking for!! I like how it slopes down to flush with the hood almost immediately after the opening... It looks OEM, and that's what I'm shooting for.
Nd4Spd,
It's funny that you posted that, because I've been eyeballing that exact scoop for a while. I've seen it on 2 other CarDomain MX-3s, and it's the closest thing to my goal that I've found so far. It looks ridiculously clean on a white car, If only I could find a flat black MX-3 with it.
Subaru has very tame hood scoop, yet functional. Mom drives 05 and I really like that car. This particular hood scoop is almost unnoticeable at first, compared to STI which is more of "in your face" Mopar Hemi hood scoop.
Magnum s/s lines, strut bars, carbon fiber bezel, indiglow gauge, Sony Xplod, inverted c/f hood, SRD lower tie bar '93 GS SE '95 Cobra SVT #2722 '68 Charger R/T 440 http://www.cardomain.com/id/mitmaks
My truck will eventually get a functioning Tacoma-style scoop on it, help blow cold air onto the supercharger. There's a hood scoop for the diesel Xterra I could use because it uses a TMIC, but that would have to, of course, be imported from overseas...
1992 Mazda Mx-3 GSR - 2.5L KLZE : Award Winning Show Car & Race Car ['02-'09] (Retired) 2004 Mazda RX-8 GT - Renesis Wankel : LS3 Coils, BHR Mid-Pipe + Falken RT-615K 245/40r18 2011 Mazda Mazda2 GS - 1.5L Manual : Yozora Edition (1 of 500) 2003 Nissan Xterra SE - 4x4 Supercharged : 2" Body Lift, 4" Suspension Lift & 33" MTR Kevlar 2001 Nissan Frontier SE - The Frontrailer : Expedition/Off-Road Trailer Project
Mesh/alu bonnet louvres either side like a Jag XKR or Ford cossie might be quite subtle I think anything in the middle just looks too much like a snout!
(fine if you have a TMIC) but a bit nasty otherwise. Bonnet louvres facing backwards actually work by dragging the heat out from underneath .
you can buy pressed into a sheet of alu already and you could just flush them into your bonnet.
I've been thinking about it, too. I want to do a recessed scoop like this; http://digitaldtour.files.wordpress.com ... c_0869.jpg
If you want it to be invisible, you could do one like mine in the turn signal, or like marcdh's, in the fog light hole.
I should have specified, I forget that not everyone follows my worklog and plans.
This is NOT for cold air induction... It's to cool the intake manifold directly. I am using the left fog hole in my MazdaSpeed bumper for cold air induction, that problem is already 90% solved. I just need to figure out how I'll shape it, since those fog holes sit a little lower than OEM euro ones... I'll need to have an angled inlet, from the bumper to the enclosed filter. Keeping that part of the bay clean is going to be a royal PITA. That's for another time though...
Back on topic, I've thought a fair bit about using the top slot in the MS bumper for this purpose, but it's not close enough to the IM to force the air in that direction. I'd rather not cover up the front VC just to direct the air, so the hood scoop is unfortunately the only feasible option in front of me.
